Steering Dimensions needed...
2001XJ
Canton, MI
If any of you out there are running the RuffStuff Specialties GM Crossover steering WITH offset TREs, can you tell me what length I should cut off the tierod tubing so I have the wheels aligned correctly with some adjustment?
I will have to figure out the draglink once installing but the tierod dimension should be the same no matter the height of lift. I asked RSS if they had a pre-measured dimension for the Dana 30 and they did not.
TIA
yeah, i know, just want a baseline..
