- Thornton, CO
How would you guys compare this to the currie system?
Heims vs TREs, I'd prefer the Currie.
So you dont have to modify the sway bar links and the tb? How would you guys compare this to the currie system?
DJ, this has to have been your jeep. There's not a spec of dirt on it.
I got mine from the dealership...............:dunno:
Right, no messing with the track bar or sway bar links. It's beefier than the Currie, it's OTK, and I think it's a little cheaper.
It's a real nice option if you don't want to get into fab work.
havent read through the tread yet. sorry, but i have the rugged ridge steering from cse offroad. brand new with a warranty with dom tubing for $180 shipped. get it on ebay its like 10 or 20 bucs cheaper then everybody else. and its a complete bolt on.
"Beef up your ride with Rugged Ridge steering components. This is a bolt-on solution for preventing bent tie rods from wheeling with larger tires. The tubes are 1.25" ID SAE 1018 that is cold rolled, pierced, and drawn through dies to produce wall thickness of .25". this true DOM tubing with no seams or welds to fail. Heavy-duty 7/8" rod ends feature standard tapered ends to fit stock knuckle applications. You get one ton strength without any modifications to your steering knuckles."
http://www.4wheelerssupply.com/catalog/product_info.php/products_id/73040
edit*** im on 35 mtrs and im at 6.5 inch of lift with stock pitman arm(havent installed my droped arm yet)***
Rusty's
Pros: None
Cons: Rusty's makes it.
