- San Bruno, CA.
Richard, the lower end of the Currie draglink actually has an improved angle over the stock setup.
How is that possable without raising the mounting location at the knuckle?
While the Currectlync steering system will fit all of the previously mentioned vehicles, John Currie indicated that the kit functions best on vehicles equipped with some degree of lift. This is due to the fact the Currie steering components are much larger in diameter than stock and require a bit more clearance for unobstructed operation, as well as because the drag link is slightly angled to better maintain proper steering geometry in a wide range of lifted Jeeps.
I was running a custom Tera/JKS/Currie/CrawlerTech/WJ setup on my '99, but at 7.5" of lift. At 5" or less, the Currie will not inhibit your rigs capabilities at all.
Mike-G actually carries an entire spare currie steering setup, on top of the currie steering he has under the front of his jeep.
I suppose that works, but really..
Letterman does the same.
I passed a guy on the Rubicon a couple weeks ago with a broken Currie drag link end. Sucked to be him.
I couldn't find a better steering setup than OTK WJ when I was building a D30.
At 5.5" of lift my draglink had the slightest angle to it. Driving on the road was a dream.
You can buy pretty much everything you need from JKS now with only some minor welding required.
If I were to do it again though, I wouldn't have used the WJ TREs on the draglink I'd have used the GM/Chevy "1-ton" TREs and built my own draglink.
Just your ability to pop into any auto parts store in america and grab a replacement TRE before driving a thousand miles home?
Actually, a Currie HD TRE is 22mm, not the 7/8" that they claim. So a ZJ TRE should go right on. When I called them on it (delayed my steering upgrade), their answer was "well its close enough".
I had WJ TREs and a JKS draglink setup on the Tera knuckle. For the tierod, I had one custom made and threaded to accept Currie HD TREs.
Thats exactly what I did, it worked really well.
I think if *I* were doing it again, I'd use rod ends, though.
The problem lies when you go OTK with the draglink on WJ TREs.
You end up needing a RHD draglink TRE at the knuckle. The only place I've found that manufactures it is Crown, and the quality has slipped.
I got mine from the dealership...............:dunno:
Wanna sell it then?
Look into Rock Krawler. It's a good setup. It looks a little odd where the drag link passes the tie rod, but it works.
It's OTK and you don't have to move the track bar. All you have to do is drill out the knuckles.
