merdock69
- Dallas, TX
Well, I spent yesterday installing my Sprintex supercharger and new gibson header. So far so good; no CEL's good power (although I think my tune is a little on the over-conservative side). I'm using the same tune file that CobraMarty used from Split Second on my FTC1. I'll need to spend some time tuning it.
A couple of lessons I learned during the install.
1) If you're going to replace the exhaust bolts with studs as Boostwerks did, then you'll need to make sure you get a shorter stud for the 4th lower stud as there is a primary that interferes with that hole on the Gibson headers; you can make it work, but it is a pain and you must use a an open end wrench to tighten. (I fully expect to have to replace this when I get more time).
2) The Power Steering pump bolts are too long for the boostec s/c manifold and will need to be cut down, they're like 90mm and I couldn't find anything longer than 60mm, so I had to cut down what I had and make it work.
I'll post a pic of it finished later, but this was about half way through.
