explorer
- rosemount,mn
ECU88XJ said:By this theory, there would be no tire chirping when turning corners on the street because the inside wheel would be governing the 'slower turniong wheel and allow the outside tire to freespool. Every automatic locker i've ever witnessed will chirp when you gas it aroung a right hand turn from a stop. I'm going to have to agree with kid here; when you're on the throttle, the axle shafts are locked together, thus turning the same speed... Well as long as your locker is working properly...
The tire chirping is because your spinning the tire. It doesn't mean the axles are locked together. It spins easily because your only powereing one tire until it catches up to the other side at which point both will drive. I could drive my Lockright equipped TJ all day and not chirp a tire as long as I was very easy on the gas. The Detroits I've driven were the same way.
