Ok, I have some quick questions. I got some bigger tires and my rear leafs are sagging to the point I do not want to take it off road. The lift I have now is around 3.5" but like I said the rear sagged so it is less than that. I am planning on going to 4.5". What do I need? I was going to get...
Longer brake lines.
Quick disconnects for the front.
Either spacers, or new springs in the front.
New rear leaf packs, no aal.
Bar pin eliminators for the rear shocks. Front shocks should be good.
I was thinking about trying a t case drop, just until I can get a sye. Do you think I will get vibes with out the sye. I have shims in the rear and it was at 3.5" with the shims with out problems. If I add a 1" t-case drop and get the rear to 4.5" I would think it would work. Am I wrong?
Do I need to worry about the pitman arm? When do I need to get new upper control arms? I have RE LCAs already. Any think else I might be missing. Again this is mostly a temporary fix until I can do bigger things. I just want it to work right, with out any problems. Thanks for any help...
Longer brake lines.
