FordGuy
- San Clemente, CA
I run a smog station and napa is full of shit. Go to a competent muffler shop the can order OEM replacement cat. We use them all day long, and there half the price.
Napa $100, Crystler was over $300. About how much is your retail cost at your shop?I run a smog station and napa is full of shit. Go to a competent muffler shop the can order OEM replacement cat.
If I was you I'd find out what is wrong: my 97 has probably 180K miles on it (hard to say exactly as the cluster got swapped out couple times) and it passes cleaner then new with nothing fancy done to it.over2land said:I've got a 98 XJ with 201 K miles on it. It was tagged as a gross polluter before I got a tune up done and O2 sensor (upstream) changed. After that, it passed, but only barely, and I don't think it will pass again next year.
nopeMy question here is twofold: 1) Will that sensor trigger a code if the Jeep is "running too clean"?
I think that all they do is look to make sure there is one there.2) Short of going to Johnny's smog guy, what are really my odds on passing/not passing (assuming no codes)? I mean, it'll be a physically larger than stock unit, it'll have the O2 sensor, the Jeep will puff cleaner than the day it came off the line... I think I'd be good... but really dunno.
I'm trying to remember the discusion and the end of it, but for some reason I remember reading about loss of power/performance when going with a bigger diameter exhause due to the loss of back pressure. You might want to look into that before upgrading.Oh yeah, reason for upsizing the diameter of the cat is that I'm looking to go to 2.5 inch pipe from the header all the way out... and if I end up with non-mandrel bent stuff, I'm thinking of maybe 2.75 or 3 inch to make up for the crimps in the bends.
