WarGin
- New Milford CT
I PROMISE you no shaft we could find would fit, they were all too small.we checked with the diff cover off and they were just grinding against the slots for a larger daimeter shaft. We were at a complete loss. The day we actually measured with a micro we found that the outer splines were the same, hence the joint swap to the old axles. I will look into it further should it ever break again, and it will, so this is to be continued.
