ChuckstrPT
NAXJA Member #791
- Birmingham, Alabama
So I'm hacking up my overhead console to fit my CB into it...cutting with an air recip saw, and die grinder with a small cut off wheel. I think I've just about got it in there, fairly cleanly, Except....that saw and cut off wheel gets the plastic so hot, I got some melty stuff, and generally not smooth edges. I'd like to keep the interior looking presentable. Any suggestions on smoothing and shaping the plastic? Can I just use a sand paper drum in the dremel/die grinder? Hand sanding? what grit? Or file? I'm sure there are some master fabbers out there. Steer me in the best, fastest direction!
Thanks!
Thanks!
