- Hammertown, USA
Back to the point, I'm going to throw another recommendation in on drop brackets. Easy on the wallet, easy to install, and a *great* ride. Just make sure your control arms are 'strait' and not the J-bent.
cal said:Back to the point, I'm going to throw another recommendation in on drop brackets. Easy on the wallet, easy to install, and a *great* ride. Just make sure your control arms are 'strait' and not the J-bent.
vetteboy said:Although I'm at odds with most in the rest of this thread...I'll agree with this.
After two R&Ps and two shafts I dumped my D30. I was running 33x12.50 SSRs, btw. I'm not crazy on the throttle (aggressive yes, crazy no), but I don't like to have limitations on how I wheel. Never broke a rear shaft (27 spline 8.25 at the time I had my '30), but had nothing but problems with the D30.vetteboy said:No way in hell I could ever recommend with a clear conscience that anyone try bigger tires with that axle.
mikereid350 said:alrighty then i think i will go with the drop bracket way... i don't need mad flex so a long arm is not need....some one said that i need straight arms not "J" bent arms... what is a good short arm kit for 5" to 6"...??? whos got what and what works a what doesn't... i only want to do this once bc shipping and dealing with the border fees and there crap suck.
IXNAYXJ said:btw. I'm not crazy on the throttle
-----Matt-----
You've never seen me go balls out, so no you can't.WaXJ_Skier said:can I call bullshit on this?
IXNAYXJ said:You've never seen me go balls out, so no you can't.
And things are a little different now with a HP D44 with alloy shafts and Superior joints. I feel a little more confident running the same size tires that I used to run on a D30.
-----Matt-----
Hell, snow runs are about finesse.WaXJ_Skier said:do the pictars count? and what about teh snow run?
IXNAYXJ said:Hell, snow runs are about finesse.
And no, pictures never do justice.
-----Matt-----
Shit, that's nothing; that was only second gear!WaXJ_Skier said:This looks like on it pretty hard.
http://img.photobucket.com/albums/v637/Avanteone/Naches 7-26-07/Naches7_26_07-128.jpg
IXNAYXJ said:Shit, that's nothing; that was only second gear! @ 5k
-----Matt-----
