where can i buy the shims that go on the lower control arms where they mount to the unibody? you know the ones that go in the mount so you can space the arms forward or back when aligning it?
I believe there's as much as 1/2" of adjustment available in those LCA frame mounts. Dunno if I have enough to go that much....... but any good alignment shop should provide the necessary shims to get it aligned - IF it's alignable with all the mods.
