Alright guys, I took your advice on going with a budget lift. I have decided to only go with like an inch or two of lift with shackles and I guess what you would call a spacer for the front strut, and 30'' bfg a/t's. Does this sound practical? I decided not to go with a 3.5'' lift because it is my daily driver. I also dont want to sacrifice gas mileage and so on. My question is what size shackles should i get for the rear( my rear sags a little) it sits lower than the front. so i want to get more lift for the rear to balance it out, how much lift im not too worried. but what do i do to lift the front. is there a spacer you put ontop of your spring? or what lifts the front. and will i be able to fit 30x 9.50 with no problems? also will this throw my speedo off. I looked around for similar advice but coudlnt find anything that i clearly understand. i found its easier just to ask the specific question to my needs. I'm up for any thoughts or ideas as well as concerns.
Thanks again guys
Thanks again guys
