jmeloxj
- greenville NC
I have just baught searchers 4x4(http://www.searchers4wd.com/home.htm) steering set up and by far it is the best i have ever seen! the kit it made up of: a custom tire to tire tierod made of 1.5"x.250 DOM high quality 3/4" hiems,a custom draglink made of 1.5"x.250 DOM using quality 3/4" hiemsand 2 sets of misalignment bushings for the draglink ends and 3/4" also all grade 8 hardware. this is a beefy set up!!! it makes my axel tubes look tiny and as for the install it was a snap !!! all that is needed are simple hand tools;2 jack stands 3/4 drill bit, drill(1/2" shank) hammer wrenches and lock tight and a strong enough pitman arm puller!!! i broke mine tryen to get it off~ i was able to do a complet install in under 2 hours!!! the worst part is jus the drilling of the holes and thats it! thats the worst part everything else is a snap!!!!This kit replaces a weak link with beefy parts but also reduces steering slack to increase responsiveness!!!! i have been very impressed with the proformance of this! They are very fast and very nice about everything!!! any problems or anything even to just check in and see the status of the work they are doing for you they are jus glad to do some work for you and get their name out a little more. I can't say enought about them, they can fab up jus about anything you need all you have to do is ask.
all of this is just my 2 cents so please dont take offence to this i am jus passing on all the good news i have gotten from them!
