Beezil, the suspension was tested without any springs or shocks to be bind free. The jam nuts are there because i was too lazy to remove them but they have not been bolted up. There are also RE SF joints at the frame side of the long arms. Now tell me what extra force is applied on the lower arms if i run just one upper? Show me the math that proves that the bushing had to give because of that fact.Beezil said:these arms are meant to twist/articulate at the threaded section. Users who choose to add jam nuts are stopping the rotation of the arm, and in a limited range of motion, something has GOT TO GIVE. If you stop the arm from rotating, flex will cause fatigue. Rusty never intended for users to stop this rotation with jam nuts. He is not surprised that this would happen. Rusty also instructs users to run BOTH uppers. He cannot honor warranty claims for users that run ONE arm.
When it is understood that the arm may have failed because it was forced into a range of motion that exceeds the bushings ability to give, failure is guaranteed.
interesting.........
Everybody is talking about the fact that i just hav one upper arm that caused the lower to fail but no one has an explanation why the force on the lowers is greater if i remove an upper arm. Come on, this is basic math, it's impossible that 2 lowers fail before 1 upper arm gives. :rtm: If the upper would have failed you would never have seen anyy posting from me about that. But the single upper could take the load that 2 lowers couldn't.
Before you start argueing about my suspension design do some math and you will realize that the upper should be the part to fail, not the lowers. Removing the second arm eliminated all the bind in my suspension. I maxed out the shocks and when i remove the shocks i can raise the chassis enough that i can remove the springs without removing the 3" longer bumpstops that i use to prevent the springs from falling out. And i hold every bet that the RE joints i welded in instead of the broken metal will withstand every abuse.
OK, some other companies tried to go with a single upper and they failed. My design works, there is just a piece of sheet metal that was not strong enough because it was overheated during welding that caused structural fatigue. That's the point that caused this thing to fail and it will not fail a second time. I'm more than happy with the front suspension design and i will not change it because it works. I'm sure the time i ran 2 uppers did the damage to the bushings because i had so much bind that i ripped of the axle mounts of one upper arm a few times. The 60 housing does not give so the bind was transferred to the suspension linkage.
Do what you want to do, buy Rustys stuff or don't, i just posted this failure to show people what can happen and they should be careful. I always check my rig after a trail run because i had so much different failures. The last failure before this one was a broken steering box output shaft. Maybe i wheel my rig hard, maybe i put too much stress on it. I don't care, i beef it up and see what gives next.
But i'm sure i will not break any Rusty part a second time. :nono:
