jcroffroad
www.jcroffroad.com
- Kalamazoo, mi
If you go OTK with our kit you MUST(read no way around it).
Remove sway bar end link mounts (axle side.)
Cut/Remove Factory Steering Stabilizer mount.
Trim the front of the Coil Buckets.
Drill and Ream the Knuckles from the top.
Adjust the steering stops.
If you already have our UTK kit and want to go OTK, you will need new knuckles and you will need a new passenger side TRE (ES2233L).
If any company tells you that their OTK kit does not require the work above, they either have the steering bend outwards or they are just not telling you the truth in order to make a sale.
On our UTK kit, it is just drill the knuckles and pitman arm and ream them out. Install steering and done.
