Not the first, when we started with these there were 2 others made and they were tube like street rods. These are the first and finest of the right kind
These do keep and utilize the original factory bolt holes for the original crossmember, as long as their kit is a bolt-in to those cross-member holes it should work just fine.
You actually use those crossmember bolt holes to hold the rails on the chassis while you weld everything up.
