XJCruiser
- Saint Marys, PA
tayman said:the off-centerdness is from the lift. your tracbar is what holds your axle centered. once you increase the angle, it has to move, so it shifts which ens up pulling your axle to the drivers sida a little. I think you would have noticed if a control arm came loose. Get on your back under the thing and look at it/grab and try to shake stuff. if anything is obviously loose that shouldn't be, then fix it. I don't know why you'd get rubbing all the time on only 31's. something's messed up. Is a piece of your fender liner or flare loose and drooping down hitting it? I might've said this earlier, but I had 31's on my XJ stock for a while, and it only rubbed under tight turning in the front. and over big bumps with a lot of weight it would rub in the back.
i have an adjustable track bar and everything is tight...if my camera wouldnt have bit the dust id go out and take a picture of it...you can clearly see that the drivers side of the axle is pushed back towards the drivers door and the passenger side is towards the header panel....
