eflores
- Greg's place
Re: Ross's Box and Sticker Collection
Jeez I didn't realize u still had a jeep!
Wade, what's the length on your LCA's? Im probably gunna setup my frame mounts like yours, just inboarded a little bit.
Rock anchors
I know I know, I was thinking about going off the inside of the framerails too. Even if I drag them, Im not really worried about damaging the 3/8" wall LCA's, lifetime garrentied forged chromo joint housings, or the 5/16" brackets. Also, I think by having the mounts lower like this I might be able to keep the UCA mount all/mostly under the floorboard.
Got the knuckles all done. Everywhere got plated with a layer of 3/16" then I added a chunk of 3/4" plate on the front for an area for a 5th bolt. It got beveled and welded on with two passes, followed by a second layer of 3/16" that captured it and welded on even more. Both sides top to bottom are now 3/8" plated. Im just waiting the high steer arms to show up so I can drill/tap/finish the knuckles.
Has anything that he's done made sense? Just smile and tell him "Good job" so he'll finish it.Amazing work here but was it really worth it?
It only adds one bolt and you are still out a keyway and the knuckles themselves are only $440 for ones with keyways.
http://www.solidaxle.com/ProductCart/pc/viewPrd.asp?idproduct=39&idcategory=8
