Well, I'd be your guy. I had a gen 1 system, Broke it.
Read , they sent me the gen 2 system, for free
Read, broke the upper arm bolts and the same week they replaced all there customers, Bad design.
So now I've got the re redesigned Gen 2 Rockkrawler 8" long arm. Things you need to do that they dont say.
1. Defenitly get some sort of high steer. Steering sucks.
2. Plan on limiting straps, bumpstops, and rear bumpstops. None of which are included. (But nobody includes this stuff anyway)
All that said. Heres some of my jeep at URE
More
In general the front end works really well. I have experianced some unloading while climbing, but I think this will be solved with a limiting strap in the middle. The only thing I dont like at this point is the front works to well. The suspension isn't balanced out of the box. But I think that all manufactures are building in as much possible flex into suspensions that they can. Even though most of it ends up being unbalanced and youhave to fix it anyway.
I guess my advice to you would be to do it all yourself. Search on here and on pirate. Buy a few steel cutting tools, cut up your brackets and arms, take them to your local welder and have him weld them up. You'll probably come out cheaper, have some new tools, and have learned somthing in the process.
