- Lafayette, California
True, but if you run rocks in the Sierra range, you won't have those pretty aftermarket flairs after you run your first 100 yards !!
ty20404 said:yeah, except anything less than 4" BS on an 8" wheel is going to cause a little excess stress on the hubs and all of the other shit in there...
for that big of a tire, i would say 4" or 3.75" BS
RCP Phx said:Can anyone confirm the backspace on the Rubicon wheels?
That is definately incorrect(did you see the previous post)!Alot of the confusion is where people measure from.Wheels need to be measured based the tire beads, not the outside edges(which very greatly depending on steel vs alloy and other things).Spoke with a workmate today who has a Rubi,he still insists that they are 4.5-4.75" based on the info I just stated.My factory 16's measure out at 5".cal said:5.25"
RCP Phx said:That is definately incorrect(did you see the previous post)!Alot of the confusion is where people measure from.Wheels need to be measured based the tire beads, not the outside edges(which very greatly depending on steel vs alloy and other things).Spoke with a workmate today who has a Rubi,he still insists that they are 4.5-4.75" based on the info I just stated.My factory 16's measure out at 5".
Goatman said:Not really an issue. On an 8" rim 4" backspacing would put the wheel mount surface right in the middle of the wheel.
You must be using "fuzzy" math,last time I checked half of 8 was still 4!TunaSoda said:Technicaly, an 8" rim with 4"bs would put the flange off-center by 3/16"
RCP Phx said:You must be using "fuzzy" math,last time I checked half of 8 was still 4!
RCP Phx said:The thickness of the wheel center has nothing to do with it,some alloys have a 1" web.A 8" wheel w/ 4" backspace is exactly centered!
Your math is good,but thats not how they measure backspace,its measured from the WMS!TunaSoda said:Say the flange is 3/16" thick and it is dead center in the 8" rim
It's mounting face to the bead edge would be 3.90625" not 4"
A rim with a 4" bs would put the flange .09375" off center
codyj86 said:dear god.... who cares. you're arguing over a frickin 3/16" i don't think thats going to make to much of a difference......
