Fred85
- Orange, VA
I've searched but couldn't find anyone with quite this issue. I just replaced my motor mounts and transmission mount, which definitely cured some 'thunking' noises underneath. But, now as I'm driving at highway speeds (50+ mph) I have a loud rumbling noise which I can also feel under my feet. If I lift my foot off the accelerator, the noise completely goes away; press the accelerator, and the noise/rumble returns. The more I press the accelerator, the louder the rumble, so it seems it is more RPM-related than speed-related. It also only occurs in the 50-65 mph range. Occasionally, if I'm driving and lift off the accelerator quickly, I can feel a rumbling vibration beneath my feet.
Suggestions on where to start looking? I checked the front diff pinion and front t-case pinion and both felt tight with no side-to-side play. Thanks.
'01, 197k, 4x4, AW4, 2" OME lift, hack-n-tap SYE (rear pinion is angled correctly).
