8Mud
- Central Germany
The last time I had low idle it was the TPS ground. The ground always seemed to test out OK, but my ground was just bare wire lying inside of a crimp somebody forgot to crimp shut. Many people jump the TPS ground directly to the chassis, I just fixed what I had and made sure it worked right. As a side note my TPS ground ECU side was in the tranny connector, and the TPS tranny side ground was in the ECU side connector, somebody assembled it bassackwards.
IAC make sure the seat in the TB is clean, spray the piston/plunger with spray oil, let a little oil run behind the piston. Don't try to move the piston with your fingers or compress it. Clean the connector. Make sure your battery voltage is OK and your system is charging properly. The IAC needs all the volts it can get to work properly and is often one of the first things to act up when something is off in the charging system.
