Mike1331
- Folsom, CA
I just switched over from my 87 30 non disco to a 92 30 with abs and the larger u-joints. I ditched the abs switch and bought 92 rotors, pads and took the calipers from the junkyard with the axel. The calipers will not fully close on the rotor. Do i need to convert to a newer master cylinder? i'm thinking the newer master may have a bigger valve in it to pump more fluid to create more pressure to push the piston out.
