souske
- The land of competition
You absolutely have to have electric trailer brakes
drop the big tires and get electric trailer brakes, and stay out of OD
Golen stroker. 270 hp 320foot lbs torque with stock intake and exhaust.
305 hp and 370/380 foot lbs torque with 99+ intake, good header and exhaust, cold air intake, big throttle body, and other odds and ends. (it's been a while since I talked to them so I forget some of the specifics)
That'll do it.
Ok, I'll bite. But for a Golen and everything required I'm looking at easily $5k - $6k. That's a whole lotta money for 100 horsepower when I can sell the XJ, put in that much cash, and get a nice V8 WJ or WK.
becuase we aren't spending 5-6K on stroker swaps.
we're spending like 2500..
$2500 is more DIY...
Gotta remember OP needs it done sooner than most people can DIY one.
Though I've still seen more DIY one's not end up being reliable in the long run.
I'm more of the party of putting in a motor that was meant to have in those numbers of HP/Torque.
Though I still think $2500 is too much to put into a 4.0L, unless you absolutely can NOT move from a 4.0L (i.e. required per class specs, etc.).
Don't get me wrong, I love the 4.0L...but spending much money on them will never make much sense to me.
Much like polishing a D30 to try and run 37's.
I'd agree with you, but then we'd both be wrong.
This is coming from someone with two strokers, one budget, and one full tilt race engine. My partner has a stroker, most of my friends have strokers..
Yes, you'll get more out of an LS swap, but I'd say a stroker is better than a non LS SBC swap.
Locally, its also easier than having your car recertified for a V8, which is a LOT of work and puts you into stricter inspection specifications.
you just now realized that your resale value doesnt go up when you add stuff to your XJ? ...
I'd have to call BS on the difference of ~35hp by adding 99+ intake, exhaust, header, etc.
MAYBE 15hp, and that would also be the removal of the piece of crap mechanical fan and getting and electrical.
Now lets see what we could reasonably and conservatively expect to gain from each component:
-99+ intake-Maybe 5-7 hp maybe more.
-good exhaust header and upgraded cat, muffler, and 2.5" pipe-10-15 hp
-large throttle body and injectors- maybe 2.5-5 hp
-good cold air intake-2.5-5 hp
I'm digging these conversations, BTW. Such good information and viewpoints.
I've got an '00. Already have it.
Got the cat-back exhaust. A high-flow cat is under high consideration. However I have the Cali-spec emissions, so I have the 2 pre-cats as well.
Bored out TB and replacement injectors are in place. Flow rate on the new injectors is similar to stock.
K&N FIPK installed. Seriously considering replacing the element with a dry AEM instead though.
