I agree. If I was going to have only one locker and one open I'd lock the front run rear open
The front is going to have a helical lock its hybrid of lsd and full locker
It is not even close to a locker. Trust me. Limited at best. A full case locker up front is what you need to lift the front over obstacles. A lsd in the rear will let the rear pivot properly it tight turning and offer a bit of help in climbing loos terrain.
I have seen them in action in the rocks. Helicals always loosen right when you need it locked. It is very frustrating. Honestly id rather have an open diff then spend money on an lsd. Imo
Now one more thing is there anyway to identify the spline count on the 8 25 without pulling the axle I don't remember the year of the xj these came out of
The helical I was going to get was a Yukon Spartan but after reading so.e of the replies here I did some more looking in to it and agreed that probably wasn't what I was looking for now I'm in a toss up between the Yukon grizzly and the powertrax grip pro can I'm not in any way interested in dropping a g just in to a locker for the d turdy I just don't wheel it enough to justify that but I do want some value-longevity I'm hesitant to squeeze the trigger on either of them but either way I'm going to need to change the carrier for the 4.56 gears so it makes sense to get the case like those provide
A helical limited slip is just that a limited slip and nothing more. The eaton truetrac is the best one out there and for snow or street racing they are fantastic. But the dont belong in the rocks.
Just so we are clear on terminally. Spartan is not a helical limited slip. It is a lunchbox locker. Ratchets when coasting allowing a differential action. Then when power is applied it locks both shafts together as a spool would. For light wheeling and mud these are acceptable. But the design is weaker than a full case locker because it relies on a stock open carrier.
All do respect before you try to correct me on the Spartan please look at the link
https://www.amazon.com/dp/B08L8DFGW4/ref=cm_sw_r_u_apa_fabc_87XJXF6AS2B4C6CH8NZC
I don’t know what kind of off-brand product that is. Most people are going to expect “Spartan” to refer to Yukon’s product, not that. https://www.yukongear.com/downloads/productsheets/spartan locker.pdf
