garr
- Nassau County NY
I replaced some badly corroded RC drop brackets with a new set of RE DB, Seems the RE lower control arm pockets in the brackets are too tight, I had to spread them open a bit just to get the LCA into the bracket, I'm sure they would fit better if I removed the caster adjusting insert, but the RE instructions say to use it.
How tight should the control arms be?
Should the move freely up & down or does bushing flex allow for up down movement?
