alexgalexg
- Connecticut
Alright I am officially stumped.
Vehicle will rarely and randomly just lose power. Almost as if it's about to stall. It happens maybe once every 1 hour of run time and lasts about 3 seconds so diagnosis is difficult. Only ever had it happen while driving, not at idle. Sounded kind of like a cps so I purchased a dealer one and installed. While I was there I noticed rodents had chewed on the wires for the cps (vehicle connector side) so I replaced the connector and wires as well. I was also gifted a new throttle body with all new sensors off a jeep going to the scrap yard so that's on there too (throttle body and sensors must have under 1k miles). There is no vacuum leak as I recently had a smoke test done in order to confirm my fuel vent tube was bad which has now been replaced.
I have looked for any other mangled wires and found absolutely nothing, I also see nothing suspicious in the obd live feed. Completely out of ideas here, I don't expect anyone to really be able to answer this as none of you can actually come see the thing, but figured I'd throw a shot in the dark.
Sent from my SM-G991U using Tapatalk
