jeepinandy
- SWVA
I would reccomend never reusing old U bolts. New ones arent very expensive
Unless you have to. I hate the damn things, but it was the only way the new 3" coils were going in. 20 years in buffalo=I'm not touching the LCA bolts untill I get new LCA's.Fergie said:Do not waste money on a compressor. The way I described works better than a compressor and takes less time. Last time I did mine it took less than 30 minutes.
Cher- Calipers makes perfect sense now. I didnt assocaite the lift to stretching brake lines as I have had YJ lines on mine, and that was never a problem.
Fergie
PS- DONT USE THE COMPRESSOR.
youngbuck98xj said:Auto Zone rents for free. Just pay a deposit and when your done take it back and they refund your money. That is if there's one around.
Okie Terry said:1st: Listen to Fergie and Cher's method.
2nd: Forget the compressor.
You'll be fiddling with death, my man.
youngbuck98xj said:I picked up compressors for $9 at the baltimore expo. With them there is no need to take of the lower arms or the calipers. Just the shocks, track bar at the axle side and the sway bar.
Storydude said:Pssst...With compressors, you can crunch that spring down to about 12 inches. EASY to fall out without removing calipers.
Ha Ha. Stay out of the plane of movement, and you have nothing to worry about. FWIW, when I took the 86 apart, EVEN AFTER grinding the spring perches to allow for more flex, they were not going in. and, on a 20 y/o vehicle, I'm NOT gonna try to get the LCA bolts out untill I had new LCA's and bolts in my hand. I've seen 2 compressors fail. One Snap-on, the other OTC. In BOTH cases the screw sheared. Damage? One screw through a buddy's hand, and the other one through a wall. That's 2 times out of about 500 I've used compressors. I hate the damn things with a passion....but sometimes they save you hours and hours of work.red91inWA said:PSST...done this about 6 times. NEVER with a compressor. once you get the rig up there is NO tension on the spring....
Compressors are good for struts...NOT necessary for anything else.
PS...compress the spring to about 12 inches...that bad boy fails and it'll take off your head.
SAFETY....try it sometime. It works.
