Darky
- 29 Palms, CA
No, they will stop your axle.So they're not bump stops but bump slows? What's the point then
Maybe, depending on various factors. But I think it's a mistake to just assume they compress 60% and no further. The more you load them, the more they compress. But it's not one to one -- it's as the name implies, progressive.
But still, not an absolute hard stop. That's what the custom plastic insert is for.
Except the pitman arm, right?Maybe? Wrong. They do when set up properly.
I air mine out and beat the piss out of my MJ and it takes it very well.
Gonna bump this. I've got my xj with 3" and 31s and. Have zero bump stops even the factory ones were gone when I got it. I was thinking of welding a 1/4" round plate to the bottom of the top bump stop tower, (where the factory one bolted in). And then using a peice of 1" or whatever length needed 1.5" tube/pipe to "tune" the prothanes a to a deffenant stopping height.
My question comes it on what size to buy? Do I just measure from the bottom, of the bump stop tower to the spring pad? I see people leave a 2" or so air gap, why?
Gonna bump this
I see what you did there lol
And air gap should be closer to 1" IMO
It actually varies depending on your setup
Basically the bumps are a spring, but with no spring back.
You are wrong. They spring back.
