Blaine B.
- Northwest Indiana
Well I understand, but will one strap make a difference?
I can rig up something to replace that strap if so.
1985xjlaredo said:Good to hear that a company still takes good care of there customers. Some one should send a link of this post to them so they can see what a good example it is to do right for the consumer!
DaveKerwin said:I have used radiatorbarn.com as well, was very satisfied.
IslanderOffRoad said:I ordered the 3 row, any idea how long it takes them to ship?
pauldo39 said:I think you may be referring to radiator.com, where you have to go through the so called "online chat with a service rep". Radiatorbarn takes you straight to two options, all metal 2 or 3 row.
I agree with what you're saying; when I was looking for radiators I went to radiators.com and the whole chat thing just turned me away.
Maybe I'm confused here.TRCM said:Most currently, I just print out the quote, and take it to autozone, and they price match it.
DPG said:In response to your e-mail- several things come to mind here for me- generally speaking-
I don't know which brand of radiator that is. There are certainly more than 1 brand of 3 row out there. I like the CSF rads best so far, and their 3 row definitely outcools their 2 row. Another companies 2 row might be their best, but it depends on a number of variables.
I've never seen that band bow out under the compression of installation. If one actually did, I'd think THAT particular radiator was obviously not right. If that were the case, good for them to warranty it. Very much NOT something you see happening out there though.
These things happening are usually attributable to bad motor mounts and/or the wrong fan clutch. Many people don't know or notice that a lot of the aftermarket fan clutches sit a good deal farther forward than the factory unit does.
If you combine a fan clutch that sits closer to the radiator (bad idea) with a thicker hi-cap radiator (good idea) and maybe toss in some worn motor mounts as well, (bad idea) you can easily have radiator damage.
I've NEVER seen a thicker radiator damaged when the motor mounts are good and the fan clutch isn't too tall. There's simply a minimum amount of space you'll wanna see between any radiator and fan clutch to be safe.
My factory motor mounts on my first '97 XJ failed at around 50k miles!
They were only about 3 years old.
I've been running MORE bombproof mounts ever since.
Of course, (off subject a little) NEVER, NEVER mount anything to the radiator via strips that mount through the radiator fins!!!
Just some food for thought...:wave:
lbsnowryder said:Dirk, they do sell the CSF. I got the 3 row. As i already stated the motor mounts are about 2 months old so i know that isn't the issue. You brought up an excellent point on the Clutch Fan though. After the incident i pulled my old fan clutch out and mesured just to be sure. The new fan clutch from NAPA was around 1/4" longer. One of the tabs on the clutch caught the band and threw it sidewayz into the radiator.
Radiator barn was really close to deniing my warranty but the fact that i've had it 2 months and never gone over 40 mph may have weighed on their mind.
How would you have handled the situation?
IslanderOffRoad said:Quick question for the threadstarter
when you say they sent you a replacement in 3 days, is that 3 days from when you called in, or 3 days from when they recieved your defective rad?
The one I got from them had a bent flange on the radiator filler/cap mount, and it leaks from the radiator cap. I need to send it back to get replaced, wondering what the time table is as I'd like to wheel it next weekend.
