Now ... we have to set some parameters down.
First ... I did not want the arms/joints to end under the frame rails. That's a major ground clearance issue. The factory LCA brackets sit at 5 degrees ... which puts the arm squarely under the rails if you make an arm with an square cut (no additional mitering). A mitered/angled cut is an acceptable way to change your arm location. But how about new brackets? Going this route gives you freedom to change many things.
Second ... A baseline has to be established. Measure anything and everything you can on your suspension. Height from ground to LCA bolt (on axle & frame). Height from ground to UCA bolt (on axle and frame). Get those same measurements for your track bar. You'll need to get width measurements between the arms as well (at the frame and at the axle). The more information you have here ... the easier it will be to build a suspension that has similar characteristics to what you are used to (or perhaps want to change).
Third ... I need to be able to fit everything in one package. The doubler adds some extra DS length and changes the angles. And a D300 does not locate as far over to the driver side rail as a NP231 might. Lots of measuring & planning here.
We already know the doubler has already been in place for some time. Due to the extra weight and length ... some new crossmembers are needed. So it made sense to integrate the arm mounts to the crossmembers. That allows me to raise up the joints and tuck them out of harms way.
Bored, huh? Okay --- let's move to some fun technical terms and why we have to consider them. For the time being, I will only concern with terms related to the front suspension. For simplicity sake, I am going to give the definitions in lay man's terms. If anyone wants better or more technical definitions ... check Pirate4x4 or try google.
irate1:
AntiDive .... The ability of your suspension to counteract nose dive during heavy braking.
Instant Center .... The imaginary point where the LCA and UCA meet way out in the distance (as viewed from the side). It can also be the imaginary point where angled upper or lower control arms meet in the distance (as viewed from above or below)
Roll Axis Angle .... How the body pitches/yaws/leans around the imaginary centerline of the chassis (Roll Oversteer/Understeer are related to this).
Roll Center ... Measured Height for where your chassis/body pivot laterally
S
eparation ..... The amount of distance between your UCA and LCA at either the body or frame. Will affect where your Instant Center meets and will affect your Roll Axis
Okay .... so what does this all mean? No clue !! I fell asleep half way through typing this. :speepin:
