Justpunchit
NAXJA Member #1291
- Jaffrey, NH
oh wow.. I feel like a total newb. I never use metric stuff... thanks for the catch. haha
OH and I also got 10.25 bolts for my bearings last night as well haha, forgot to grab pics however.
get those ballistic fab brackets mounted up yet? did they fit together pretty nice, i gotta set coming in the mail this week
call me crazy, but if you so desired, how would you take the leaf spring off if there is no bolt....? or had you not drilled a new hole yet?
one tiny comment: you mention that 8.25 has a cast pumpkin. it is specifically cast iron. cast just refers to how the metal was shaped. iron, steel, aluminum can all be cast (or forged, for that matter...) the fact that the pumpkin is cast iron is why you need to pre/post heat. and technically should be using a high nickel content weld rod/wire... but you can get away without that.
looks pretty good otherwise.
correct, cast steel means no need for pre or post heat.
i've never welded cast iron with regular filler material. scientifically, it does make a difference... but it does work either way. you're just more likely to develop cracks if you don't use the high nickel content rod. cooling whatever you weld while surrounded by sand is an even better way to do it too.... it's slower than cooling it in air. i think i've heard of high nickel content wire... once. but i can't remember where...
i admire your dedication and workmanship, excellent job u can tell this is not your first time, really great info and details thanks i have learned quit a bit, just curioius when u removed the rear floor, did u drill all the spot welds or just cut it off, really does look great
