OK... I've tried the search feature and have several ideas, but none that I think are really my problem.
About 2 months back I had to replace the Drivers Side Door catch. No problems there as of course I had to take off the interior door panel and unplug the power locks/windows switch. After reassembly and plugging the switch back in the power windows wouldn't work, but the power locks worked fine. So I unplugged the switch and cleaned up the contacts (the little brass male parts on the back side of the switch) and plugged everything back in. After messing around a little more I got the windows to work. Thought everything was fine...
Then a couple days later the Power Windows wouldn't work again. Then after turning the ignition key off and opening and closing the drivers side door... they worked. There is not real pattern as to why they do or don't work, but every once in a while (say every 30th time the drivers side door is open) they quit working.
It's as though there is a short somewhere, but I can't tell where and doin't really have an idea where else to look. Perhaps I knocked something loose when I pulled the interior door panel and door speaker out to replace the door catch... but I don't know what.
Any suggestions? The windows work fine when they actually work (if that makes sense). Doesn't sound like the motor is going bad and it's not making any bad/strange noises.
