MATTVW65
- Layton Utah
this is a short list if there is something I have that you might need or are looking for call or text me at 801-725-0112
Matt
2000 Xj engine 4.0 accessories on engine $800
1990 xj engine 4.0 $200
1998 xj engine 4.0 has a rod knock $100
Rubicon express upper rear control arms super flex adjustable zj or tj $100
Rubicon express lower control arms ft or rear adjustable super flex Xj tj or zj $150
Rubicon express upper control arms super flex fixed xj zj or tj $100
Rubicon express lower control arms ft or rear fixed super flex Xj tj or zj $150
tearaflex adjustable lower control arms
xj tj or zj $100
skyjacker fixed lower control arms $40
skyjacker track bar $50
rear overhead speaker tray $50
teraflex 2" lift shackles $100
sky jacker extreme drop pitman arm $100
rubicon express drop pitman arm $40
skyjacker bump stop set $20
transfer case drop kit $20
tearaflex quick disconect set $40 4" lift
full s.s.t custome built sway bar disconect set $100 for 8" lift
jks bar pin elimator set $20
rear lift blocks 3" $15 2" $10 steel 3" $20
1 1/4 wheel spacer set 5x4.5 $50
dash cluster 97+ $50
ft drive lines $40 each
steering gear box $40
1994 8.25 rear axle $100 3.07 gears
1994 dana 30 axle complete $200 3.07 gears
1993 dana 30 3.55 gears $200
1996 dana 30 3.07 gears $200
xj dana 30 4.10 gears lock rite $250
xj dana 44 rear axle 4.10 gears and full spool $400
1997 zj dana 30 3.55 gears $200
1997 zj dana 35 3.33 gears $200
2000 xj dana 30 3.55 gears $200
2000 xj dana 30 housing $100
1996 ax15 transmission $400
1994 ax15 transmission $400
1996 231 transfer case $200
197ish chev dana 44 with flat top knuckles $150
cross over stearing arms $40
ft 2000 xj drivers side seat $100
rear 2000 seat $40
1997 front seat drivers $100 passenger $50
rear $40
01 fuel tank with pump $50 each
Matt
xj tj or zj $100
rear 2000 seat $40
rear $40
