Laurent Wagoneer
- Boyle Heights,CA
So my Exhaust Mani was gone so I decided to shop for a header. I have a Renix so only option for me under 250 bucks was the pacesetter. After research, it seemed like I would gamble on a good or bad product from them. I took the gamble and ended up with junk.
Holes for bolts that connect to Cat won't line up. Then the biggest issue, the step washers provided to make up the difference in hight from the intake Mani and the exhaust Mani. The hight difference is about a 1/4" on the bottom bolts. Pacesetters solution, get some washers, cut them in 1/2 and stack them. My solution for them, make the Flange thicker to OEM specs!!!
Returning this junk and going with OEM Dorman manifold from Vatozone. Lifetime warranty.
