It really depends. Some of the more expensive aluminum radiators use much wider tubes and have more surface area which can be more efficient. The cheap 2 row aluminum radiators with plastic tanks do not have this. I'm pretty sure there was a very long thread covering this. If you need something rugged and easy to repair at home the CSF 3 row is a good option.The aluminum 2 row will transfer more heat then the 3 row copper
