WebDog
- Center City, MN
Any progress on a universal drivers side mount? Optima or not?. Have a 2000 XJ and I want to do the second battery...
Does the top bracket on the Universal Battery Tray work with Odyssey batteries?
Checking in. Need a new tray. You shipping out yet?
I'd skip DB altogether. Unless he has changed something, the 34/78 I have does not fit into the tray that he claims it should. Service was fast, until I had a problem, then he magically disappears and hasn't responded once.
I would be curious to see pictures of what isn't fitting.
I am running the DB tray and an Optima yellow top, and it all fits fine. I wonder if Optima has made a change? That could pose a problem down the road.
Has he finished his move? He said he would be moving out of CA and sitting up else where so he would be hard to get in touch with.
I guess we could look at his site.
EDIT
Here you go if i did it right.
https://www.dirtboundoffroad.com/dirtbound_is_moving
EDIT 2
Hey i did, not bad for this old guy.
My redtop doesnt fit either. Im not sure if its because of the plaster holder that came in the lid of the optima that you need to secure it to the tray or the hole pre drilled in the tray. My plastic holder was a little rough looking and even though it has that groove that the bolt goes through for adjustability it will not move close enough to fully secure the battery. You can either open up the slit on the plastic holder piece so that it can slide tight against battery or re drill the hole in the tray that it bolts to. I will take pics in a few to show what im talking about as i have not fixed mine yet.
This is what I'm working with. The battery slides around about 1/2". You can see that the plastic holder piece just can't get close enough to secure it
