It only looks like it's about 1-1/2" to 2" off to me. If that much. It looks like the front flares have been moved up and the rears haven't. That makes it look less off.....but there's also some rear clearance to be had by moving the rear flares up to match the fronts. I'd move the flares up and try and find a used set of ACOS spacer's.
If I was going to be replacing the front coils.....I'd just get the coil with the total lift that I needed and take out the front spacers. That way, you could use them at a later date whenever inchitis strikes again...LOL. Plus....the new coil prices are pretty close no matter what size they are. At least, to a certain degree, they are.
Aron
EDIT: "maineiac.......actually the springs are cheeper"
This is even more reason to get the actual amount of lift that you need and keep the spacers back for a "rainy day". IMHO
