sure thing. depending on your backspacing with the narrow wheels you may rub your inner fenders and LCA's at full lock. as far as the bead seating it will be fine.
Fit with what lift,the second poster has been "smoking" something special!
I currently run 265/75/16's on a 6" lift using stock wheels.I used to run 33x 10.50's.
What kind of stock 16" wheels are you using? I really like the 265x16" size, a buddy runs MTRs that size in his YJ but I like stock wheels. I'm presently using 15"x8" TJ five hole wheels & like the way they look & fit. I've just learn to live with the rubbing on the lcas. I suppose some day I'll adjust the stops to cure it.
He asked if they would fit on those WHEELS. He was concered about the width of the rim, not if they would fit with the amount of lift he has! He didnt ask "will X tire size fit under X lift amount." :wave1:
