THEBIGWHITEONE
- Fort Myers FL
Replaced the RMS and oil pump. Went to install the pan and the pick up is impacting the pan. Took it out to make sure and it the pan goes in fine. Its from advanced auto parts and the oil pump is from Milling. Pickup was sold separate. Do I need to go get OEM I'm a good 1/4 inch off or can someone post up some part #'s that work. I have a 98 xj limited if that matters.
