I cant get it off. I am using the type 60 torque socket with a 3/8" open end wrench, with a breaker bar on the 3/8". I have use penetrating oil. WD40. I don't know if i should use a torch to heat it? What gives? I am afraid of breaking the torque bolt and then having to pull the whole motor to fix a little bolt. All I am trying to do is fix a damn oil leak and it is more frustrating than replacing the rear main seal. Anyone run into this before?
2000, 4.0L
2000, 4.0L
