alosix
- Abingon, MD
Yucca-Man said:Ahemm...What about a 96 231? It uses the same t-case output as the 97+ XJ, and other than the shifter mech they're the same as the TJ...
Auto XJ case is NOT quite the same as a TJ case. The XJ AW4 requires a short input shaft. TJs tend to have the long shaft. Otherwise they are the same and interchangable.
FWIW, what exactly is wrong with your case? Where is it leaking from? This could be a result of the SYE installation (bad seal on reassembly). You might just need to take it apart again and re RTV it.
231s are a really simple setup. I had mine completely torn apart and reassembled in about 1.5 hours (changed SYE to super short SYE and swapped the input gear.). If you did an SYE then you've taken it more than 1/2 way apart already. 4 more bolts and one lock ring and it willl fall completely apart.
Jason
