FixYourShorts
- Thornton, CO
I searched threads first, but didn't see any exactly like my problem. I have a slight knocking coming from the rear end. It only happens when I'm moving, and it increases with speed. My guess is that it is either a u-joint or something in the rear diff. Just so you all know, here is my set-up.
2001 XJ with 140,000 miles. Roughly a 6 lift on 33" BFGs. The lift is a 4.5 RE short arm flex kit with 2" shackle extenders and 1.75 coil extenders. I've got a Tom Woods shaft with a slipyoke eliminator. Both diffs are stock DANA 30 and DANA 35, repectively. I have had this set up for about 5 years. I haven't wheeled in awhile, but when i did, it was my dd, so, I didn't abuse it.
Anyone have a similar noise? Solutions?
I don't know much about gears, but I have an ARB ring and pinion set for the DANA 35 (not installed). Is there a possibility that installing this will replace the potentially problematic parts?
