MaxxXJ
- Bakersfield CA
ive never seen the one above the pedals on the driver side, just one under the hood and 1 on the passenger kick panel
Yes, that is where the manual tranny would have a master cyl on the older models. But sorry, I am confusing you with irrelevent info. The key facts are that the lights work on the left side, but not the right. And they ALL don't work on that side. Check the ground. Your fuse box is in the older location, and other thread bandits turned it into a late model issue so everyone was talking about the right front kick panel. Forget about that. Trace down the ground wire from that (right) light (probably black) and clean up the ground connetion or run a new ground to a sheet metal screw in the body.
Look at the right tail light, not the fuse panel. Get underneath to look or pull the tail light out of the fender. Find the black wire, take a wire with a safety pin and push it into the black wire and hold the other end to a good ground on the body ane test it.
Actually, if you have an voltmeter or test light, take out the tail light bulb and hold the probe to the pin in the light bulb socket. Hold the other probe to a good ground and see if you have power. Then try it holding the second probe to the shell of the bulb socket. If it workds good to the body, but not the socket, you need to fix the ground either by finding the old one and cleaning it or running a new wire to a sheet metal screw.
