RE-xtremeXJ
- Smithtown, NY
So I bought a set of bushwhacker cut-out flares for my 01' XJ only to see the directions are less than to be desired. I have installed my RE 5.5" kit along with bumpers and rock rails, so the actual work is not the problem its really just the directions for cutting the fenders that makes me weary.
·For the front fenders, do you have to completely remove the body molding on the newer XJ’s or should I just try to cut it.
·When I make the cut, should I follow the portion of fender that is popped out for the factory flares or do you just trim the front and rear. (I have to fit my 34’s)
·In the factory directions it says to make a line 7 ¼” from the bottom rear of the fender, then in the provided illustration, it's marked at 5 ¼”?????
·Should I leave the bolt holes on the top of the fender like the illustration???
·And the directions for the rear are even worse!!
~~Please any info would be much appreciated; for the front or rear~~
Thanks -Mike
Thanks -Mike
