- Bakersfield, CA
I just went out and looked at it. The top of the control arm is actually hitting the shock mount on the passenger side (opposite side of the current problem). It is bottoming out and not allowing me to lower the axle any more on that side. I would rather not have to trim that though. I need to move the axle forward about half an inch. The only thing I could really attach the come-along to would be the front bumper...
It is standard procedure on a lifted XJ to cut or grind some off of the bottom lip of the shock mount to provide more clearance for the control arm. There is plenty of material there, removing enough to get better clearance isn't an issue. You can use a grinder to just grind on it, or a cut off wheel to cut a hunk off. You don't need to cut much off, just enough to let the axle drop the amount you need to use all of your shock length.
