scottmcneal
- not here
I use bolts to set my doors back on.. Just easy for me to do it that way..
O.K. so i realize it has been a long time but i figure i'd post an update. I taped some yarn across the top section of my hood, so that they would flutter in the wind as i drove, (like when you tie paper stripps to a fan) to see how the air flowed over the hood, and to see if air was sucked into the engine bay by the scoops. I was pleasantly suprised at how well the worked, at speeds as low as 25MPH the yarn an inch or so in front of the vents actually turned right around and blew into the scoops. It was really pretty cool to watch, they seemed to defy laws of physics. The hood continued to induct nicely up to about 70, which is the fastest i went, altho i dont see any reason it would change at higher speeds. I would say that it looked like i was really sucking in a lot of air too. The yarn going into the scoop seemed to be fluttering just as fast as the yarn taped to the very top. This was definitley much cheaper than buying a cowl hood. I wish i had some temp readings so i could see if there is any disernable change in under-hood temps but i dont see why there wouldnt be at least some change. I am very satisfied with the result, thank you all for your help as well.
i did this for five bucks didnt wont to cut the holes out made a 1 inch spacer kit
