IntrepidXJ
NAXJA Member #647
- Grand Junction, CO
First off, here's my specs:
1992 XJ Laredo, NP242, Auto, 4.0
OK, starting a few weeks back, whever I would switch into full-time 4wd, I would get this strange clicking noise around turns (similar to the sound when you turn on pavement in part time 4wd). Anyways, the sound definately didn't sound good, so of course, I quickly tried to put it into 2wd, however, the noise remained when going around corners. It kind of seemed like the TC was stuck in Part Time 4wd. After some testing in gravel, I seemed to be in 2wd, yet the clicking remained. After a while of driving, the sound disappeared.
Anyways, long story short, everytime I try to go into 4wd, this situation continues to happen.
Not being sure what the problem was, I changed the gear oil in both diffs and the TC (Mobil 1). While I had the diff covers off, I inspected inside, and though I'm not an expert with this stuff, I didn't visually see anything that looked wrong.
This morning, I tried full-time 4wd again, and the same thing occurred...however, after putting it back in 2wd, I went home and jacked up the front of the Jeep with the wheels turned right since it was still making the clicking noise.
I was able to spin the driver side front tire freely, and the front drive shaft spun as well, and no sounds were heard.
When I got to the passenger front tire, it would not spin, and when I tried to spin it, it would make that clicking/clunking noise that I've been having. The sound seems to be coming from closer to tthe tire than from the diff, or TC (but I'm not 100% sure on that?)
While I had the wheels off the ground, I checked for play in the u-joints, but they seem to be OK.
Anyone have any ideas for me? I am completely lost, and don't know where to start.
Thanks for your help!
