1998 4 door was bone stock. I started yesterday and pulled front and reat diffs to do the regear and lockers. So I didnt take any picks during the pulling diffs part I figured that had probably been covered enough.
Now that all that is out ill be pulling transfer case for the sye this week and installing frame stiffeners Then rc 4.5 la lift. So far I only had my sway bar links on the front snap off.
Both my hub bearings are bad also.
Ill also be droping oil pan to replace gasket and rear main seal. New rotors, turn drums, and pads and shoes.
So as stated next will be the frame stiffners. So ill take some photos of that if any of you want me to. Just let me know.
I ment to take a before photo and I forgot.
