Must I always destroy the bearing???!!???
Explorer 1
Whittier, Ca
When I need to replace the seal on my rear axle, must I always destroy the sleeve and the bearing in order to remove the leaky seal? :gonnablow
Is there some kind of puller that at least can save the bearing?
Thanks in advance,
Fred
Explorer 1
I'd suggest maybe trying to find the root cause of why you need to replace seals often enough for this to be a problem...
This is a given, first time I've replaced the seal. Hopefully, the last for a while. I've just never had to replace the bearing on this axle before.
Thanks, as always, an ounce of prevention is more than worth a few tons of pressing.
Fred
Explorer 1
